hacesoft
Dec 08, 2019Tutor
ACL rules
Good evening, i have 4 VLANs for the switches. I played with ACL rules and I was not successful. I always blocked my entire switch perfectly with the first rule. Information I draw from : - u...
- Dec 11, 2019
Hi hacesoft,
Please following the configuration below:
2.VLAN 11 perimt access internet and special address camera _1 / camera_2 , Right ?
Configuration ip acl "VLAN11"
permit destination address 192.168.20.20 --- permit specail address can access form vlan 11
deny destination subnet 192.168.20.0 0.0.0.255 --- deny 192.168.20.0/24 subnet
deny destination subnet 192.168.30.0 0.0.0.255 --- deny 192.168.30.0/24 subnet
permit any any ---- permit access internet and other ip address
bind your vlan11 port inbound
3.VLAN 20 permit access all vlans and no permit access internet,
you just can delete 192.168.20.0(vlan 20) static-route on your Route
4.VLAN 30 only permit access internet
permit any any
bind your vlan30 port inbound
Notes:
Please see attachment examples about ip acl
kevin_hong
Dec 09, 2019Apprentice
Hi hacesoft,
Welcome to community,
Let's clarify your request one by one.
1. Management switch: Only special ip address can login and management switch
--- you can set access control, then no other address is accessible
2.Disable access to special address from VLAN 11 to VLAN 20, Right ?
--- i need more detail information about it. such as deny vlan 11 ipadd 192.168.11.10 access vlan 20 192.168.20.20.
Please provide more detailed requirements for acl
Thank you
hacesoft
Dec 09, 2019Tutor
Good evening,
in the attachment I send a picture describing how I want to configure my home network.
Perhaps it is more visual than a verbal description ...
- kevin_hongDec 09, 2019Apprentice
Hi hacesoft,
Thank you for your feedback.
First, Let's clarify your needs.
1.Only one pc can access and management your switch(You don't need a configured vlan 40)
--- you can set access-control on your switch
2.VLAN 11 perimt access internet and special address cancea_1 / cancea_2 , Right ?
Are these correct ? Did i miss anything?
- hacesoftDec 10, 2019Tutor
Good evening,
almost everything is right, but the stimulus difference is that I want the VLAN20 too.
Otherwise you understand it well from the drawing.
OK
YES
YES + permit access internet
YES
