ljlj83
Jul 18, 2023Aspirant
ACL to protect telnet or ssh on GS110TPP
Hi all, I have a GS110TPP on firmware 7.0.9.12. From reading and experimentation I have figured out that the unit has both a telnet server (port: 60000) and ssh server (port: 22); each of which ...
schumaku
Jul 19, 2023Guru - Experienced User
ljlj83 wrote:
On that note, I see that ssh is supported for the GS110TP. Is there any way to get a firmware working for the GS110TPP?
All GS108Tv3 / GS110TPv3 / GS110TPP share the same firmware version, v7.0.9.12 as of writing.
Talking of the Netgear Lite Command-line Interface (CLI)? Initially, the Lite CLI was introduced for select models only, in this line the GS108Tv3/GS110TPv3 7.0.9.5 and above, indeed. Well possible, this development is stuck ...
ljlj83
Jul 19, 2023Aspirant
Thanks very much for the reply. I figured as much.
As per the OP, is it possible to configure an ACL of some sort to protect the telnet port on the switch?
I'm able to automate the enabling/disabling of PoE on each port via telnet but really don't want to leave that unsecured.
