Ciscoisthebest
Jul 24, 2023Follower
Best version of software
Hello, I need to update the switches and I don't know which version is the most recomended right now? Model Name Boot Version Software Version GS728TPPv2 1.0.0.5 6.0.4.6 Model Na...
- Jul 24, 2023
Head to https://www.netgear.com/support/ and enter the correct model according to your product model label ... and you will get offered the appropriate downloads.
https://www.netgear.com/support/product/gs728tppv2#download
https://www.netgear.com/support/product/gs728tp#download
schumaku
Jul 24, 2023Guru - Experienced User
