cjharman
Aug 29, 2023Aspirant
Brightspeed Fiber to GS108E to Google Wifi Pro Mesh
Hi Friends, I have Brightspeed Fiber and I am trying to skip the modem, and having a little bit of trouble. Here is my current setup. Everything is working, but I do get a double NAT. Note: B...
Aug 29, 2023Guru - Experienced User
I'd ask the ISP if there is any PPPoE configurations needed to pass thru or maybe put on the Google Mesh Router.
Might try installing the Google mesh router connected to the Fiber ONT directly to see what happens there.
The ISP should be able to help you on this.
cjharman
Hi, I spoke with Brightspeed, and they said there is no PPPoE config for their service, it uses IPoE. Also, no luck with plugging the Google Wifi Pro mesh direct to the ONT
đ
