DWSam
Feb 04, 2022Follower
Cable Test Failures on GS324TP
I recently purchased the GS324TP (POE+) switch and am having trouble with my POE cameras. I do not own a separate cable tester. The cameras will randomly recycle, leading me to believe the power ...
DaneA
Feb 09, 2022NETGEAR Employee Retired
Welcome to the community! :)
Since you have an ongoing support ticket with NETGEAR Support, I suggest you to set up port mirroring on your GS324TP switch. Select a port(s) as a source port(s) on the GS324TP where the camera(s) is directly connected. Then, select another port as a destination port on the GS324TP where a PC (with Wireshark installed in it) is directly connected. Run Wireshark until the issue occurs. It would be best that Wireshark would capture the packets in the event the issue happens.
Kindly read page 319-321 of the GS324TP user manual here on how to set up port mirroring. You can download Wireshark on this link. As reference guide, check this link I found online on how to use Wireshark.
For the captured packets to be analyzed, kindly attached it to your existing support ticket. Kindly state that this will help in the investigation. You can share here the progress of your support ticket.
DaneA
NETGEAR Community Team
