nRgia
Mar 22, 2020Aspirant
Cannot tag more than 2 ports on multiple VLAN subnets
I have 2 VLANS and the default management one on pfSense(not tagged on pfSense), only 2 are tagged as VLAN20 and VLAN30 Network diagram On Netgear GS116EV2 I have the following: Switch Port...
- Mar 23, 2020I mannaged to tag them by rebooting the switches.
Thanks
schumaku
Mar 23, 2020Guru - Experienced User
Add the VLAN [U] or [T] detail to both ends of each trunk (e.g. to the left and the right of the VLAN info on the drawing, and mark the one you can't configure.
Show - from both switches - the Web config for VLAN -> 802.1Q -> Advanced (this mode must be used on the switches) ...
- VLAN Configuration
- VLAN Membership (for each individual VLAN)
- nRgiaMar 23, 2020AspirantI mannaged to tag them by rebooting the switches.
Thanks
