sr07
Oct 09, 2025Aspirant
Can't configure SFP ports (49-52) on GS752TPv2
Hi I have two GS752TPv2 switches connected via SFP and fibre to form a small isolated LAN. I need to configure the SFP port (51) but in the web gui port 49-52 is not shown for configuration, only 1-...
sr07
Oct 10, 2025Aspirant
I believe we have AGM732F SFPs installed. I don't have access at the moment and won't until on site to fix them next week, so can't report their firmware version at the moment!
I want to change settings such as: Configure VLAN trunk using the SFPs and fibre on port 51
Does the GS752TPv2 share SFP ports 49-52 with copper ports 45-48?
Or was there an early firmware issue?
schumaku
Oct 10, 2025Guru - Experienced User
sr07 wrote:Does the GS752TPv2 share SFP ports 49-52 with copper ports 45-48?
Negative, no shared ports (the printed numbers would unveil).
Not that the Web UII would hide the ports in question: Don't forget SFP and SFP+ are not interchangeable. The AGM732F are pure SFP (1000BASE-LX),
