HeckRasier's avatar
HeckRasier
Follower
Jun 02, 2021
Connect my GS752TPv2 via SFP to a cisco switch. Trunk\extend network
Could use some help. I have a GS752TPv2 that I'm trying to connect to a CISCO switch via SFP/Fiber. I can use CLI all day but this interface is killing me. Does anyone have detailed instructions of video on how to connect a net gear to a cisco switch?
Cisco switch config is
switchport
switchport mode truck
switchport trunk allowed vlan 110.
I added vlan 110 to the netgear and made port 51 (T) and assigned the PVID to 110. I'm using a generic 1000baset SFP in the neat gear and a 40g QSFP on the cisco which is connect via fiber.
Just trying to extend our network to this switch so we can use its PoE feathures for some camras. Thank you.
1 Reply
  • schumaku's avatar
    schumaku
    This makes sense: On a trunk, most VLANs (except of a dedicated one) does run tagged.
    The PVID defines the VLAN untagged frames on this port (or LAG) are sent to. Is this what you want? Probably not.
    QSFP would be using four (thus Quad) fiber pairs, 10 Gb each (the designation is unlucky, it should be QSFP+) .... how shall this ever work with an SFP pair operating on 1 Gb/s? Answer: Probably never, because fiber does not know anything like link speed negotiation. My guess your problem starts at this point: There is no 1G fiber link established at all. The Cisco single QSFP pair does 10G, the Netgear SFP does 1G.
ProSupport for Business
