Enzymhemmer
Jun 30, 2019Initiate
Connecting 2 VLAN to exchange Files with GS752TPv2
Hello everyone, i need your help with an issue i am having. We use a Draytek Router that creates 2 internal Vlans (1 & 2) with the IPs 192.168.1.x and 192.168.2.x We use VLAN1 for the Servers...
- Jul 05, 2019Hi DaneA, i have since found another solution to my problem. The Draytek Router can connect 2 VLANs so we created a third one and now this one is connected to the 2 separated ones. We can exchange files over a PC in VLAN3. This is ok for now and i wil lget back to this problem when we have to change something. Thank you though!
DaneA
Jul 04, 2019NETGEAR Employee Retired
Welcome to the community! :)
Kindly post an image of your detailed network setup showing how everything is connected.
DaneA
NETGEAR Community Team
- EnzymhemmerJul 05, 2019InitiateHi DaneA, i have since found another solution to my problem. The Draytek Router can connect 2 VLANs so we created a third one and now this one is connected to the 2 separated ones. We can exchange files over a PC in VLAN3. This is ok for now and i wil lget back to this problem when we have to change something. Thank you though!
