charlie663
Jul 20, 2025Aspirant
Connection issues in GS324TP
Hi all, I have a GS324TP model which is causing me a terrible headache. Connecting devices through the switch it goes really slow. I went to the simple case of a PC, a switch and a router. I...
Jul 20, 2025Guru - Experienced User
charlie663 wrote:f i connect my PC directly to the router, everything goes fine. But if i connect my PC to the switch and the switch to the router, it goes really slow
Have you tried different switch ports for both connections?
Any chance it is cabling?
