charlie663
Jul 20, 2025Aspirant
Connection issues in GS324TP
Hi all, I have a GS324TP model which is causing me a terrible headache. Connecting devices through the switch it goes really slow. I went to the simple case of a PC, a switch and a router. I...
Jul 20, 2025Guru - Experienced User
charlie663 wrote:f i connect my PC directly to the router, everything goes fine. But if i connect my PC to the switch and the switch to the router, it goes really slow
Have you tried different switch ports for both connections?
Any chance it is cabling?
charlie663
Jul 21, 2025Aspirant
I didn't try different switch ports, but cabling cannot be, because i used same cables to connect directly to the router. And same cables worked.
Is there any way to see logs in switch?
