charlie663
Jul 20, 2025Aspirant
Connection issues in GS324TP
Hi all, I have a GS324TP model which is causing me a terrible headache. Connecting devices through the switch it goes really slow. I went to the simple case of a PC, a switch and a router. I...
Jul 21, 2025Guru - Experienced User
charlie663 wrote:Is there any way to see logs in switch?
It is a smart switch, so you can see port status, etc.
You might want to revew the manual:
- https://www.downloads.netgear.com/files/GDC/GS324T/GS324T_GS324TP_GS348T_UM.pdf
