AP514's avatar
AP514
Tutor
Jul 13, 2020
Default Vlan not making it to the Net
I have several Vlans on my Switch..all are working(at least the ones I have something hooked to) I have the switch connected to an ER-4. I have all Vlans TRUNKING thru port 24.   My problem is.......
  • AP514's avatar
    AP514
    Jul 13, 2020
    Well, Thanks for the information about Me haveing to give a more informative set of ports and setups/Configs. I will remember it for my next set of Questions.
    I was taking screens of all my connects on the ER4 Router and of how I have my Switch configured to Post here....
    I figured a picture would be alot better than me trying to explain what I was seeing for Configuration.
    Well, While taking Screens in my Router, I saw my PROBLEM..
    Vlan 30 my IOT I had thought I had set my DHCP range smaller...had it all the way up to XX.254  So when I was trying to set my Wifi as an access point.(Static IP it was in the Vlan 30 DHCP range) I adjusted the Wifi outside the DHCP range and all is Working Great.
    So,1 problem down...
    As Far as the Vlan 1 ports not working..I will return maybe this weekend with more questions and better info on my Configs
    (as you suggested).
    Thanks for your help and support on these Forums
ProSupport for Business
