keithelm
Feb 25, 2019Follower
DHCP Address reservations ignored?
I'm working in an environment with a BR500 VPN Router and two GS408EPP switches. The switches are both connected directly to the router (no intermediate devices), and the ports on both the router an...
- Feb 26, 2019
Hi keithelm,
Welcome to the community! :)
My original goal was to enable DHCP on the switches but to configure reserved IP addresses for them in the DHCP settings for VLAN 1. If I can't control/force how the DHCP request is sent from the switch I may just resort to forcing static addresses.
There is no option to control/force how the DHCP request is sent from the switch. For me, it would be best to set a static IP address on the switches for ease of management.
If you still want to set the switches as DHCP client and acquire the same IP address from the DHCP pool set on the BR500, kindly read pages 85-87 of the BR500 user manual here about Manage Reserved LAN IP addresses.
Am I overlooking some setting that controls how the switch requests its own DHCP address (whether the packet is tagged or not)?
As I have mentioned above, there is no option or settings on the switch that controls how the switch requests its own DHCP address.
DaneA
NETGEAR Community Team
DaneA
Feb 26, 2019NETGEAR Employee Retired
Hi keithelm,
DaneA
