SailAvid
Dec 30, 2019Initiate
Forward VLAN from Unifi Switch through Netgear to Unifi USG
Hi Community! I have the following simple network setup: [Unifi USG] -- Port1 -------- Port24 --> [Netgear JGS524PE] -- Port23 ---- Port8 ---> [Unifi 8-Port Switch] -----> [Unifi WAP] Th...
- Dec 30, 2019
AFAIK Unifi does run the primary VLAN (VLAN #1 here) untagged, so change to
- Set VLAN1 Membership Port1-Port22=U, Port23=U, Port24=U
- ... (the PVID 1 for all ports is OK in this case).
schumaku
Dec 30, 2019Guru - Experienced User
