Retired_Member
Nov 01, 2017FS726 Letter of Volatility
I require a letter of volatility.
Also is there any way I can access any possible logs for the device.
Regards
Retired_Member,
Just want to clarify the model of the NETGEAR switch you are asking for the Letter of Volatility. Is it FS726 or JFS726?
What I can provide to you as of now is the Letter of Volatility of the FS726T switch. It might be that its a typo error on your initial post (I might be wrong as well on this assumption).
If ever you need the Letter of Volatility of the FS726T switch, kindly download it on this link. The link will expire within 48 hours.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Just want to follow-up on this. Were you able to download the Letter of Volatility of the FS726T switch?
If ever you were able to download it and you do not have any further inquiries or concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
Retired_Member,
DaneA
