mehulwarade
Dec 20, 2021Aspirant
Getting individual port POE values using SNMP
Hi, I am trying to get command line access using SNMP to my switch to get the individual POE values like the wattage and current. I can see that we can turn on and off individual ports in this ...
schumaku
Dec 21, 2021Guru - Experienced User
Does this still apply with the recently released firmware 6.0.10.5?
https://www.netgear.com/support/product/GS728TPv2.aspx#download
PS: Requesting a moderator to move this thread to the appropriate Smart Plus And Smart Pro Managed Switches Forum section
mehulwarade
Dec 21, 2021Aspirant
Thanks for the replies.
schumaku wrote:Does this still apply with the recently released firmware 6.0.10.5?
The link you provided is for the model GS728TPv2. My model is GS724TPv2 and the latest firmware on the download page is 2.0.7.4. That firmware is not working.
Do you reckon I can use the 6.0.10.5 firmware of GS728TPv2 on my GS724TPv2?
https://www.netgear.com/support/product/GS724TPv2.aspx#download
- schumakuDec 21, 2021Guru - Experienced User
Sorry, my mistake. Ignore that other device model firmware.
- CapricanDec 23, 2021Aspirant
The OID of PoE MIB (RFC3621) is iso.3.6.1.2.1.105,
you can find it on GS724TPv2 or the snmpwalk output file you attched before..
- mehulwaradeDec 23, 2021Aspirant
Caprican wrote:The OID of PoE MIB (RFC3621) is iso.3.6.1.2.1.105,
Hi,
Thanks for the reply. Yes I do know the OID for the PoE MIB but what I am unable to do is extract individual power values from each port. As seen from my original post, I can turn each port on and off using SNMP and now I am looking for individual port values.
If you can provide with the OID to get power values for each port, that would be greatly appreciated.
Thanks.
