mehulwarade
Dec 20, 2021Aspirant
Getting individual port POE values using SNMP
Hi, I am trying to get command line access using SNMP to my switch to get the individual POE values like the wattage and current. I can see that we can turn on and off individual ports in this ...
schumaku
Dec 24, 2021Guru - Experienced User
The switch says that it support POWER-ETHERNET-MIB which should allow me access to monitor the POE values. Can someone please help me find the exact oid that will get me the values for individual ports.
The POWER-ETHERNET-MIB (easier to read as decrypted than the MIB file here http://www.circitor.fr/Mibs/Html/P/POWER-ETHERNET-MIB.php) does various PoE aspects. For example, you find the nominal and measured power for the PoE subsystem, the PoE classes by port - but not actual power usage (Watts or Amps) by port as you are looking for.
Netgear has implemented NETGEAR-POWER-ETHERNET-MIB http://www.circitor.fr/Mibs/Html/N/NETGEAR-POWER-ETHERNET-MIB.php, the NETGEAR Power Ethernet Extensions MIB containing this or the similar information - in my understanding this is not available on this class of switches.
