ChrisB44's avatar
ChrisB44
Initiate
Jan 21, 2025
GS105E acting like an unmanaged switch
Hi all, i just pulled out an old GS105E of my storage. Unfortunatley it acts more like an unmanaged switch. If I put in on my network and connect a computer it works without an issue.   But sinc...
  • ChrisB44's avatar
    ChrisB44
    Jan 21, 2025
    Thanks for your answer.
    Actually I just realized that this is a GS105E v1 which does not have a webinterface at all.
    The way to configure that device is using the ProSAFE Plus Configuration Utility.
    Not sure if I will be happy with that on the long run but at least it is clear now.
ProSupport for Business
