ChrisB44
Jan 21, 2025Initiate
GS105E acting like an unmanaged switch
Hi all, i just pulled out an old GS105E of my storage. Unfortunatley it acts more like an unmanaged switch. If I put in on my network and connect a computer it works without an issue. But sinc...
- Jan 21, 2025
Thanks for your answer.
Actually I just realized that this is a GS105E v1 which does not have a webinterface at all.
The way to configure that device is using the ProSAFE Plus Configuration Utility.
Not sure if I will be happy with that on the long run but at least it is clear now.
ChrisB44
Jan 21, 2025Guru - Experienced User
Roger that. Crazy how some of these switch have web pages and some don't.
Glad you figured it out. Should be able to reset the switch thru that app too, if needed.
Enjoy.
