Rodos
Dec 30, 2023Aspirant
GS105Ev2 Update Firmware Beyond V 1.2.0.5
I have an unused GS105Ev2 Plus Switch that I have been playing with. On an apparently misguided whim, I downloaded and flashed the original V1.2.0.5 firmware to the device. The switch still works, bu...
schumaku
Jan 01, 2024Guru
Npcap installed with the admin-only mode? In case of yes, you need to launch the ProSafe Plus Config Utility as administrator. I guess starting the utility does not request admin privs.
Rodos
Jan 01, 2024Aspirant
I'm logged in as administrator, and even explicitly running as administrator makes no difference.
- schumakuJan 01, 2024Guru
Worth a try to uninstall and re-install Npcap with raised privileges.
Don't have a current status - some times ago, the Admin-only installation was depreciated, look here https://ask.wireshark.org/question/12350/admin-only-mode/
- RodosJan 01, 2024Aspirant
Uninstalled, then re-installed Npcap as administrator, then re-ran ProSAFE as admin (and normally) with no switch detected.
