mschle
May 30, 2022Aspirant
GS108E not accessible over tagged VLAN
Hi all, I have a backbone switch which is connected to several GS108(P)E v3 switches. The uplink port contains 3 VLANS (30,31,32) which are tagged on that port. These switches distribut the 3 VLANs ...
- May 30, 2022
Thanks Kurt,
I re-thought everything after reading your post and concluded it could not be something on the GS108E v3 which were setup identically. So it had to be something on the backbone. I finally noticed that accessible GS108E v3 were connected to a port which had the PVID of the VLAN I want to contact the GS108E v3 over. I never expected this PVID to be of any influence on the tagged ports. After I set the PVID on the tagged ports on the backbone switch correctly I was able to manage the GS108E v3 centrally over the backbone / WLAN.
Thanks again - M.
schumaku
May 30, 2022Guru - Experienced User
Most of these Web configurable switches are not built on a managed switch core with a management VLAN and a management core handled by an untagged management CPU connected to an internal untagged port. There is a small microcontroller listening on all frames passing the switch, taking care on e.g. ICMP multicast or the managment IP stack. No management VLAN, the controller does not deal with tagged frames.
Technically, it does not matter over which VLAN the untagged management frames are going in and out of the microcontroller, relevant is just the IP subnet and IP adddress.
For simplicity, run the management VLAN for these "Plus" switches untagged on the wired backhaul all over your network, keep all other VLANs tragged.
Few newer 10 GbE and Multigig Plus switrches (xxnnnEx) are implemented on a management core - there is a proper management CPU on a management VLAN. These behave more like a managed switch - something these Web managed Plus switches were never intended for.
Regards
-Kurt
mschle
Thanks Kurt,
Thanks again - M.
- schumakuMay 30, 2022Guru - Experienced User
In brief, the way I understand the implementation:
The IP stack on the device does "listen" to all the traffic on the network. Only untagged frames are ending on the IP stack, tagged frames are not untagged and never taken as IP packets.
From this is my conclusion that the VLAN network for the config handling must be run untagged, (VLAN nnn [U], PVID nnn).
- mschleMay 30, 2022Aspirant
Well, see here the VLAN setup of my backbone XS716T:
If I understood it correctly I only have tagged VLANs here since VLAN Member and VLAN Tag and Tagged VLANs are the same for each port. However the PVID entry must be 31 if I want to access the config page of the connected GS108E v3 (connected to xg7 ... xg12). Does the PVID make the respective VLAN untagged ?
Thank you for your insights ... M.
The PVID does define the VLAN where untaggged frames will be associated to. There should by a related setting per port defining VLAN 31 [U], too to make it correct.
