pierrelowe1
Dec 07, 2021Follower
GS108E VLAN 1
Hi there. I have setup a GS108E switch to simply split incoming data from subsea equipment into VLANS. The setup works fine on the GS105 version of the switch, and for the most part the 8 port versio...
DaneA
Dec 08, 2021NETGEAR Employee Retired
Welcome to the community! :)
Be informed that all Smart Managed Plus Switch Models, which includes the GS108E, does NOT support Management VLAN.
If you need a switch that supports Management VLAN, kindly check the Smart Managed Pro & Smart Cloud Switch Models and the Fully Managed Switch Models of NETGEAR. Kindly access the link below:
NETGEAR Business Product Catalog Volume 19-1 - check pages 45-66
DaneA
NETGEAR Community Team
- schumakuDec 08, 2021Guru - Experienced User
For this use case, the Plus models are prefectly fine, assuming there are not mch risks involved. Just keep the VLAN 1 untagged.
