SteveBarrera
Apr 13, 2022Follower
GS108Ev3 - how do I display the MAC addresses of the connected devices?
In the management portal, under System/Management/PortStatus, I can see a table with the Port Status for each of the 8 ports. I would have expected to see the MAC address of each connected device in this table. However, all that I see are things like up/down, link speed, max mtu, etc. But no MAC addresses. Is this possible? Note, that I do not have any advanced features like VLAN enabled. This is just my first use of this newly purchased managed switch.
Hello Steve,
The GS108Ev3 Plus switch doesn't have an "Address Table" to view the learned MAC address per port. The Port Status allows you to manage the port speed and to view the status per each port. Please check User Manual on page 59 for more info.
Mary
1 Reply
- Nodism1125NETGEAR Expert
Hello Steve,
Mary
- Apr 12, 2023Retired_Member
