p789
Feb 08, 2024Aspirant
GS108Ev3 defect?
Hi, I bought a used GS108v3 that according to the seller should be fine apart from port 1 not working, however when I connect it to power all I get are two blinking LEDs: Both power and (bizarrly...
schumaku
Feb 08, 2024Guru - Experienced User
p789 wrote:
I bought a used GS108v3 ...
a GS108Ev3 in this case.
If the reset key press for some 2..5 secinds does not recover, I fear you have a broken switch, indeed. Some internal power supply logic likely defect.
PS. Have requested a moderator moving this thread to the more appropriate Plus And Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management, as this isn't a Managed Switch at all.
- p789Feb 08, 2024Aspirant
Yes, it's a GS108Ev3.
I have tried the reset key several times already but to no avail.
I have read postings about installing new firmware via tftp - would that be worth trying?
- BrianLFeb 11, 2024NETGEAR Moderator
Hi p789,
If it has been reset and wired to your existing network and has not given signs that you can get a connection or a LAN IP address from your network. Sadly, this unit that you just bought from someone is faulty. You can check out our list of switches that will suit your needs.
Kind regards,
- Apr 12, 2023Retired_Member
