Retired_Member
Jun 27, 2022GS108Ev3: no access after firmware update
Hello, I have updated the firmware of my a.m. switch two days ago. Since then I cannot access the configuration website anymore. The switch as such is working, but the website is not accessib...
Retired_Member
Jul 01, 2022I have tried from various browsers and even laptops. The problem is the same.
I did not do a factory reset. Won't that delete the firmware upgrade as well?
Furthermore I do not have physical access to the switch, hence I am not able to carry out a reset now.
schumaku
Jul 02, 2022Guru - Experienced User
No.
From the community prospective, some information on how the firmware update was applied.
- Apr 12, 2023Retired_Member
