normandy214
Oct 24, 2021Aspirant
GS108Ev3 Problems changing VLAN membership and port assignments
I configured my switch with 5 VLANs and then assigned the switch ports to the VLANs. Everything is working fine. Now I'm looking to move one of the switch ports from VLAN 10 to VLAN 20 andI cant fi...
- Oct 24, 2021
Add the port first to that other VLAN 20, e.g. as tagged to avoid unwanted traffic. Then you can change the PVID to 20, remove the membership from VLAN 10, and change the port to VLAN 20 untagged.
schumaku
Oct 24, 2021Guru - Experienced User
- normandy214Oct 24, 2021Aspirant
I knew I was making a simple mistake. Thank you so much for the quick response and the solution.
- schumakuOct 25, 2021Guru - Experienced User
normandy214 ... it's not really a mistake. There is in my opinion to much dependency testing implemented. So we have to use the workaround as shown above.
- Apr 12, 2023Retired_Member
