DominikHoffmann
Feb 01, 2023Aspirant
GS108PEv3 web GUI not reachable
I have set up a couple of GS108PEv3 switches on LANs for two different clients. I have configured them through their web GUIs. The problem is that after some time I can no longer access the GUI. The ...
- Feb 03, 2023
A dhcp reservation can be sufficient. Trouble is the very basic dhcp client on these switches, if the dhcp server does not answer in time these dhcpdc fall back to the default IP, makes it cumbersome to be reached.
The switch discovery (on the very same subnet) does typically unveil the default LAN IP.
schumaku
Feb 01, 2023Guru - Experienced User
What config was applied? A static fixed IP config or was there just a reservation done on a DHCP server?
DominikHoffmann
Feb 02, 2023Aspirant
I did a reservation on the DHCP server.
