cat139lyleb
Dec 07, 2022Aspirant
GS108Tv3 Firmware Update Failure from old "7.0.7.1" to new "7.0.9.11" and stuck with old firmware
GS108Tv3 did not take an update, so does anyone has the same problem? I already rebooted and tried the update repeatedly, but it seems it stuck with 7.0.7.1, so please help! Thanks!
cat139lyleb
Dec 14, 2022Aspirant
Where the manual book or something? Also how do I suppose to do with 2 ways firmwares updates, I thought it should be simple to do as same as what routers do...
schumaku
Dec 14, 2022Guru - Experienced User
There is one way for the firmware update. However there are two firmware images in place, which can be maintained individually. You as the switch admin define which image will be activated following the installation, or which image you want to have loaded following a reboot or cold start. Can't take away your learning curve.
https://www.netgear.com/support/product/gs108Tv3.aspx
https://www.netgear.com/support/product/gs108Tv3.aspx#docs
It's not that straight forward I'm afraid.
