gwaitsi
Jan 12, 2021Guide
GS108Tv3/GS110TPP 7.0.5.2 Firmware Update 2x Bugs
I have a GS108Tv3 and GS110TPP and upgraded the firmware from 7.0.5.2 on both today. I don't have a support contract, but the newest firmware has introduced two bugs; 1) accessing the switch via...
DaneA
Jan 13, 2021NETGEAR Employee Retired
Kindly try to perform a factory reset on both GS108Tv3 and GS110TPP switches then reconfigure the settings from scratch. Check if the same problem will occur.
DaneA
NETGEAR Community Team
gwaitsi
Jan 13, 2021Guide
Hi There,
In relation to
1) there has been a change since 7.0.4.8.
I had a "_" in the host name. but it worked in all prior versions (and other non-netgear devices).
I see that "-" is a valid character, but "_" is not for a host name. So 7.0.5.2 would appear to be working according to strict specifications. Notwithstanding there is an "uncaught SyntaxError: expected expression, got '<'" on the login page.
2) This problem exists (i don't know if either of the tftp upload options is correct, and only the http is incorrect). The three places to upload certificates are;
- Security / Access / HTTPS / Certificate Update (as tftp)
- Maintenance / Update / TFTP File Update (as tftp)
- Maintenance / Update / HTTP File Update (as http)
I have only tried the HTTP option, but
"X.509 Public Certificate PEM" - has to be the Service Certificate - not the Public CA
"X.509 Certificate Private Key PEM" - has to be the Public CA - not the server certificate.
So i now have the devices working as i previously did.
