Das-Atom
Apr 03, 2022Initiate
GS110EMX loosing / instable connection on the 10 GBit ports
Hello to All,
I have bought this switch and I were not able to get an stable connection establish
between the following comninations:
10 GB Switch port to 10 GBit Aquantia based ethernet card
10 GB Switch port to 2.5 GBit Intel I225-V controller
10 Gbit Switch port to 2.5 GBit AVM Fritz 6690 cable Router
On it is the same. Connections are up when I start up the end devices and after
some time the GS110 shut down the ethernet port. It was not able by unplug and plug
the ethernet cable again that the switch port starts working again....sometimes it comes
up again on it's own. But this can be after 5 minutes or after 50 minutes... There
is no chance for me to find out what is going wrong with this switch.
Does anyone else have a same problems? I have installed the newest firmware 1.0.2.3.
Any Ideas what I can do?
Thanks a lot
No RepliesBe the first to reply
