oneoff's avatar
oneoff
Follower
Dec 30, 2022
GS110EMX Switches SBS installation
Hi everyone!
I would like to use two of these devices side by side on a standard 19" server rack/ shelf.
I can't find any information about hardware options, connectors or even measurements/ screws locations for these switches.
is it possible to have them fixed closely, side by side? are they compatible with a 19" rack?
is there a connection bracket for that?
They're supposed to sit fixed on a moving machine and I'll need some kind of a solution that will allow replacing the switches or servicing if needed, while they're fixed with screws to the rack sides, and between themselves.
Thanks in advance!
1 Reply
  • schumaku's avatar
    schumaku
    To my knowledge, there are no dual-width-mount rack units kits (similar to the m4300-16x/-24xf or -8x8f/-12x-12f) or dual-10" brackets available for these desktop switches, To install the switch in a 19" rack, you need the extended rack-mount brackets and screws that are supplied with the switch.
ProSupport for Business
