harry7922
Jun 04, 2020Guide
GS110TP deactivate PoE over SNMP for specific Ports
Hi everyone, I bought a GS110TPv3 Switch because I read that I can disable PoE for single Ports via SNMP. Now I downloaded official MIBs for that switch but didn't find right OIDs. Can someone ple...
- Jun 08, 2020
The POWER-ETHERNET-MIB is a standard MIB, starting from the OID .1.3.6.1.2.1.105.
The OID .1.3.6.1.4.1.4526 on the other hand is a Netgear private MIB - this is not the POWER-ETHERNET-MIB.
The problem we're facing is a very inconsistent set of OIDs implemented on switch series which should be very similar - why ever, the popular and powerful Netgear private MIB seem to be missing on this model.
harry7922
Jun 05, 2020Guide
Sorry! Forgot to add a link. Maybe I misunderstood something.
Link:
Today I did a lot of research. But didn't find a solution.
Hope someone of you NETGEAR experts can help.
As I told, I bought a GS110TPv3 and this is supporting "POWER-ETHERNET-MIB".
I opened my MIB Browser and loaded the actual MIB (v5.4.2.16) from NETGEAR support site. When trying to get TableView of "pethPsePortTable" (OID: .1.3.6.1.4.1.4526.11.16.1.1) of "powerEthernetMIB" no table is delivered from switch. SNMP connection works. other MIBs I can access and get results from switch.
Can anyone support?
Thanks in advance.
Best regards, Harry
schumaku
Jun 08, 2020Guru - Experienced User
- harry7922Jun 09, 2020Guide
Thanks for your help!
The problem was the newbie-user an not the device!
BR
Harry
- schumakuJun 09, 2020Guru - Experienced User
Harry,
For completeness, have you discovered the SNMP MIB for enabling/disabling PoE on the GS110TP, and has it worked as per your demand?
TIA,
-Kurt
Hi Kurt,
yes that's right in the powerEthernetMIB the OID 1.3.6.1.2.1.105.1.1 (pethPsePortTable) is the starting point.
With this you can choose the correct port and enable/disable "pethPsePortAdminEnable". Port 2 for example is OID: 1.3.6.1.2.1.105.1.1.1.3.1.2
Thanks again!
BR
Harry
- Nov 02, 2022Anonymous
