wuwu84
Jan 25, 2020Aspirant
GS110TP MIBs
Hi Netgear support, can you please provide me a link to download the MIBs for GS110TP? I need it to switch ON/OFF poe admin mode via snmp. Thank you very much!
- Jan 26, 2020
wuwu84 wrote:
can you please provide me a link to download the MIBs for GS110TP? I need it to switch ON/OFF poe admin mode via snmp.https://netgear.com/support/ -> type your model, find your switch, head to downloads, and find https://www.netgear.com/support/product/GS110TP.aspx#download ... pick the MIB for the current firmware.
There isn another thread where a community member shows that the POWER-MIB are available on the GS110TP - "POWER-ETHERNET-MIB, part of the private MIB tree of Netgear, it doesn't implement the IETF OID" https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS310TP-snmp-poe-disable/m-p/1796579/highlight/true#M13644
schumaku
Jan 26, 2020Guru - Experienced User
- wuwu84Jan 26, 2020Aspirant
Hi schumaku,
thanks for that.
It works great with .1.3.6.1.4.1.4526.11.16.1.1.1.3.1
:smileyvery-happy:
