silverlight
Dec 13, 2021Aspirant
GS110TP port 60000 open
Hi, Does anyone know why there is a service running on port 60000 on this switch? My network monitoring system showed unusual SNMP traffic from the switch, so I ran an nmap scan expecting to find 16...
- Dec 13, 2021
SNMP is either polling or you see traps sourced from the switch LAN IP. Nothing else sent on it's own.
silverlight wrote:
Does anyone know why there is a service running on port 60000 on this switch? ... Instead I found ports 80, 4242 and 60000 tcp open.
...When I browse to the port in firefox, I see a page titled (Broadcom FASTPATH switching) and a list of 'Invalid username' and 'Invalid password' statements .
The ubiquitous Broadcom FASTPATH switching cli around for >> 10 years, when I have it right use admin and your switch password. Note: This is for Netgear support usage only - certain commands cnan fill or force reboot the switch.
silverlight wrote:
My boot version is B 5.1.0.2, the software version is 5.4.2.33.
Not taht it will change a lot - current seems to be 5.4.2.36 when I have it right.
schumaku
Dec 13, 2021Guru - Experienced User
silverlight
Many thanks for explaining. I connected using a telnet client to the service successfully and had a look at the options.
