alphanet
Apr 04, 2020Aspirant
GS116Ev2 port cannot be removed from VLAN1 using web GUI
Hello,
I configured my brand new GS116Ev2 switch as follows, using 802.1q Advanced VLANs through the web GUI.
My intention is that ports 1-4 have all VLANs (tagged, except VLAN 1: untagged and default PVID), that port 16 has all VLANs (all tagged except 1, and 100 as default), port 13 only the VLAN 101 untagged, 14 only the VLAN 104 untagged, and 15 only VLAN 200 untagged. All the others (ports 5-12) should be on VLAN 100 untagged and that's all.
I have however difficulty to remove VLAN 1 from ports 7-15: there is no error message but it just does not work. See captures. Funnily, 5 and 6 could be removed.
Thank you for any ideas!
PS: firmware version was updated to: 2.6.0.43
Welcome to the community! :)
Kindly try the following to isolate the problem:
a. Clear the cache of the browser you are using. Then access the web-GUI of the GS116Ev2 and try to remove ports 7-15 on VLAN 1.
b. Use another browser like Firefox.
c. Use another PC / laptop.
d. Reboot the GS116Ev2.
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
DaneA
