sniff122
May 01, 2022Tutor
GS116Ev2 unable to set port VID
I got a GS116Ev2 last year and its worked a treat mostly, but when setting a port to another VLAN using advanced 802.1q, the port VID does not apply unless i add another lower port tagged to the VLAN...
schumaku
May 09, 2022Guru - Experienced User
G'day,.
sniff122 wrote:
I got a GS116Ev2 last year and its worked a treat mostly, but when setting a port to another VLAN using advanced 802.1q, the port VID does not apply unless i add another lower port tagged to the VLAN and also select it when setting the port VID. When applying the port VID with say port 7 and 8 selected, port 7 will be ignored and port 8 will be applied. I noticed this forum post from 2020 with the exact same issue on the JGS516PE and there is a reply of someone with the GS116Ev2 having the same problem.
As replied back then, this must be a firmware (or less probably a web browser - switch Web UI interop issue.
Both the JGS516PE and the GS116Ev2 run on the very same firmware image, so same behavior is predictable.
Can't add more - convinced this is a Netgear problem should investigate since 2020 YeZ please.
sniff122 wrote:
Ive also noticed that i cant disable the DHCP client and set a static IP without loosing access to the web UI
This static IP belongs to which VLAN? How do you access that IP address exactly? Aware of the "special" design of most these "E" Web managed switches, where we have no management VLAN configurable I hope.
sniff122
May 09, 2022Tutor
Its getting DHCP on VLAN 1 and the static IP is the subnet of VLAN 1 so im not sure whats going on there, could possibly be linked with the (likely) firmware bug with the PVID configuration maybe
- JechangMay 16, 2022Tutor
Hi sniff122 ,
1. I try this issue at my local on GS116Ev2 (FW:2.6.0.48) with below steps but cannot reproduce it.
here is my steps:
1) enable advanced 802.1q vlan, create some VLANs( ex: vlan 10,11,12..)
2) add ports (ex: p1,p2,p3 )to vlan 10,11,12...
3) setup the PVID to the VLAN member ports added at step2
ex: setup port1,port2 PVID =104) change the DHCP mode to disable, and setup the static IP address ( same IP address as previous DHCP)
Any difference with your config ?
If yes, can you kindly help to share your config/ or detail steps for us to analysis this issue.
2. Does it works If you try with private mode on Chrome/Firefox browsing ?
Thank you.
Best regards.
