sniff122
May 01, 2022Tutor
GS116Ev2 unable to set port VID
I got a GS116Ev2 last year and its worked a treat mostly, but when setting a port to another VLAN using advanced 802.1q, the port VID does not apply unless i add another lower port tagged to the VLAN...
sniff122
May 09, 2022Tutor
Its getting DHCP on VLAN 1 and the static IP is the subnet of VLAN 1 so im not sure whats going on there, could possibly be linked with the (likely) firmware bug with the PVID configuration maybe
Jechang
May 16, 2022Tutor
Hi sniff122 ,
1. I try this issue at my local on GS116Ev2 (FW:2.6.0.48) with below steps but cannot reproduce it.
here is my steps:
1) enable advanced 802.1q vlan, create some VLANs( ex: vlan 10,11,12..)
2) add ports (ex: p1,p2,p3 )to vlan 10,11,12...
3) setup the PVID to the VLAN member ports added at step2
ex: setup port1,port2 PVID =10
4) change the DHCP mode to disable, and setup the static IP address ( same IP address as previous DHCP)
Any difference with your config ?
If yes, can you kindly help to share your config/ or detail steps for us to analysis this issue.
2. Does it works If you try with private mode on Chrome/Firefox browsing ?
Thank you.
Best regards.
