BassT23
Jan 25, 2024Aspirant
GS308E all VLAN, how to connect to GUI now?
Hi LL,
I had an GS108E and GS308E in my Network. All ports are assigned to an VLAN. some ports are trunked.
The Switches had an static IP.
On the DHCP the Switches don't show up, but work correctly.
Now I want to change some ports, but how to connect to the GUI now?
Connect to an untagged port don't work.
Connect to the trunked (tagged) port work like a charm đ
Fixed
These switches can't get configured (Web UI)over a trunk with tagged ports. The IP stack is very basic, it does listen just to untagged frames.
Give the https://www.netgear.com/support/product/netgear-switch-discovery-tool#download a try to discover the switch in case.
- BassT23Aspirant
Fixed
Believe what you want, the IP stack on these switches can never work when your sent tagged frames to it. To allow config access under all conditions, run the management network untagged.
