Noiseboy81
Nov 13, 2022Aspirant
gs308e VLAN setup
Hi hoping for a little assistance. I have purchased this switch in the hope of being able to connect to two different pieces of networkable hardware. Specifically, L'acoustics network manager require...
JeraldM
Nov 14, 2022NETGEAR Employee Retired
Welcome to the community!
Would it be possible if you could provide a network topology (how your devices are connected)?
Basically, you have a computer with the network manager application installed that is assigned with a static IP address that needs to communicate to your client devices (amplifiers and wireless workbenches) which are DHCP clients, is that right?
If that is the case, just basing it on your requirements, it looks like you'll need a router instead of a switch.
JeraldM
NETGEAR Community Team
