Noiseboy81
Nov 13, 2022Aspirant
gs308e VLAN setup
Hi hoping for a little assistance. I have purchased this switch in the hope of being able to connect to two different pieces of networkable hardware. Specifically, L'acoustics network manager require...
schumaku
Nov 14, 2022Guru - Experienced User
There is nothing stopping you from having multiple devices on the same network (here your new switch), regardless if some get ip configs by DHCP or some are set fixed (to that very same IP subnet of course, same gateway, same subnet mask, ...) as for example issued by your router DHCP server.
Briefly flying over these two devices specs and descriptions don't unveil any needs for bigger requirements.
