Jcam1967
Jan 13, 2025Aspirant
GS308Ev4 Tagged traffic issue
Hi all. Let´s start with a 2025 best wishes. I´m new to this type of switch and Vlans as a whole. Bare with me. I think best is to describe my setup so that it can be visualized: I have a Opnsen...
Jcam1967
Jan 15, 2025Aspirant
Hello Erwin, thanks for the reply.
You are correct. I'm using 10.10.10.0/24 and 10.10.30.0/24 as Class C
When you say to change PVID to 30 on both ports, you mean P1&P5. I have tried that, but then I lose connectivity to my Lab LAN 10.10.10.0/24 that is connected to port 1. It makes sense... I think.
--------LAN--------10.10.10.1/24 Port 1 Port 2 ------------10.10.10.10/24 - GW 10.10.10.1/24 -Nic0
OPN Vnic0 Switch PC
-------Vlan30------10.10.30.1/24 Port 1 Port 5 ------------10.10.30.10/24 - GW 10.10.30.1/24 -Nic1
See screenshots .
Have a nice Day Erwin, thanks again
schumaku
Jan 15, 2025Guru - Experienced User
There is something basically wrong with our network and VLAN design:
You can't have Port #5 [U]ntagged associated to both VLAN 10 -and- VLAN 30
