agawad
Oct 21, 2020Aspirant
GS324TP becomes undiscoverable when connected to a router
Hey all, I recently set up a GS324TP through its web UI, gave it a static IP, configured VLANs, hooked it up to my router and access points, and rebooted. Everything seems to be working fine, the...
- Apr 23, 2021
Forgot all about this thread - in case anyone was wondering, it turns out I had forgotten to change the Management VLAN ID from the default 1 to another working VLAN. VLAN 1 was reserved for my router, which is why it was conflicting with my router. Once I changed the Management VLAN ID everything worked perfectly. :catlol:
Retired_Member
Oct 22, 2020Hi agawad
Welcome to Community!
Could you please share your IP setting configuration screenshot and network topology? Does your computer connect to the switch directly?
Do you mean the swich will change to unreachable once connect to Router? If disconnect to Router, then it will be rachable? Both two scenario, switch with static IP?
We need more defailed information to debug this problem.
Eric
scalextrix
Oct 27, 2020Aspirant
I am having a similar problem, my JGS524PE works, but after a short time the IP address becomes unreachable, an arp -a doesnt show it connected to the network.
Its still switches and the config works, VLANs are working etc. but it becomes impossible to manage the switch.
