agawad's avatar
agawad
GS324TP becomes undiscoverable when connected to a router
Hey all,   I recently set up a GS324TP through its web UI, gave it a static IP, configured VLANs, hooked it up to my router and access points, and rebooted. Everything seems to be working fine, the...
  • agawad's avatar
    agawad
    Apr 23, 2021
    Forgot all about this thread - in case anyone was wondering, it turns out I had forgotten to change the Management VLAN ID from the default 1 to another working VLAN. VLAN 1 was reserved for my router, which is why it was conflicting with my router. Once I changed the Management VLAN ID everything worked perfectly. :catlol:
ProSupport for Business
