Bradders1664
Oct 23, 2022Aspirant
GS324TP D-disable mode problem
Hi I'm using a GS324TP switch in a home network environment with PoE Unifi AC wifi mesh devices and numerous ethernet ports around the home. I'm having a problem with one port connected to a PoE Un...
schumaku
Oct 23, 2022Guru - Experienced User
Best guess there is STP enabled on the GS324TP - something standard on such configurations.
If an STP configured switch does find a loop, the most likely loop port has to be shut...
Cumbersome is that especially older Unify mesh systems don't support using the dedicated wireless backhaul (and not STP).
The wireless uplink feature on the Unifi mesh was never designed to be used as a hardwire failover. The uplink feature is automatically enabled from the initial setup. If the cable goes down, it will go into uplink mode, but it's not design to fail back over when the cable becomes active. If you don't need the wireless mesh uplink feature, I would disable it in the controller.
Challenge Ubiquity Unifi support or their community FMI.
Bradders1664
Thanks, that makes good sense.
I will try this and revert back.
