ITSKrafty
Oct 31, 2021Aspirant
GS324TP is not showing the option for Insight Management and showing limited support.
I purchased the GS324TP S350 Series 24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports (190W) switch in April and am just now configuring it for a project. I have some strange t...
ITSKrafty
Finally found this:
https://kb.netgear.com/000048452/What-devices-can-I-discover-monitor-and-manage-with-Insight?language=en&utm_campaign=contactus_postsales_GS324TP&utm_medium=websiteinternal&utm_source=contactus
This router cannot be managed remotely with Insight Manager.
I still have these issues remaining:
1. It is not discoverable with the netgear discovery tool. My other switches show just fine. I can get to the local management just fine via the IP (after I figure out IP) management page.
2. It continues to tell me to register it even though it is registered to my account.
3. When I plug a cable connection from my Unify switch to this switch the port will not even light up. If I plug in via fiber it works. If I plugin a cable from another netgear switch it does light up.
DaneA
Nov 11, 2021NETGEAR Employee Retired
The GS324TP is NOT a router. It is a switch.
What is the version of the NETGEAR Switch Discovery Tool are you using?
Is the PC where the NETGEAR Switch Discovery Tool installed within the same network as with the IP Address of the GS324TP?
Since you are able to access the web-GUI of the GS324TP, for me, that is fine.
Kindly check if the Gateway and DNS configured on the GS324TP is correct.
For me, since you knew that the GS324TP is already registered on your account, you may ignore it.
Try doing a loopback test to isolate the problem. Get an ethernet cable. Connect one end of the ethernet cable to any port, for example: port 1. Then, connect the other end of the same ethernet cable to another port, for example: port 2. The port LEDs of both ports 1 and 2 should lit up indicating that the both ports work. Repeat the same procedure on other ports of the GS324TP.
DaneA
NETGEAR Community Team
