mToddh's avatar
mToddh
GS324tp open a port for unfiltered connection ?
GS324tp                 Is it possible to totally open a port for unfiltered access?
  • schumaku's avatar
    May 18, 2020
    Unless there are ACLs or multiple VLANs configured all ports resp. the VLANs are transparent. Not sure what use case you are behind here.
ProSupport for Business
