cloud3648
Jun 28, 2021Follower
GS324TP S350 fan turns on at boot up then turns off minutes later 1.0.0.34
I just noticed that The fan does not stay on like it used to when a poe device is plugged in. So i rebooted the switch. When the switch boots up, the fan turns on for about a min then its it turns of...
schumaku
Jun 29, 2021Guru - Experienced User
1.0.0.34:was supposed to address this issue and allow to keep the fans spinning. /GS324TP-S350-Elevated-Temperature-No-FANS-Firmware-1-0-0-30
Get in touch with The Customer support for ssistance.
