ShadowHawkDav
Jun 04, 2024Follower
GS324TP upstream port deactivates
Hello Everyone, I have had a GS324TP 24 port smarth switch (POE+) for a couple years now. No problems with it until last couple of months. Now, the upstream port connected to my router will r...
schumaku
Jun 12, 2024Guru - Experienced User
L2 Loop Protection enabled?
Spanning Tree Protocol enabled?
Much more likely than any DoS Protection chiming in however.
Auto-DoS Protection enabled? If yes, then with what settings?
- Nov 02, 2022Retired_Member
