TonMachielsen
Apr 10, 2019Aspirant
GS510TPP Default password does NOT work anymore after firmware upgrade
I just upgraded the firmware to the latest version and now my password to access the switch doesn't work anymore. Factory reset and configure everything from scratch again?
- Apr 18, 2019
Hi John!
Yes, i can access the switch now. UNfortunately all my configuration is gone, hence what a factory reset is supposed to do.
You can close the topic, but i think you should file a bug where after a firmware upgrade the admin password gets reset/scrambled/whatever. Reset no, because i could login with the default password nor could i login with one of my previous passwords. So i guess the only option left is that the password gets corrupted.
Ton.
TonMachielsen
Apr 18, 2019Aspirant
Hi John!
Ton.
JohnC_V
Apr 22, 2019NETGEAR Employee Retired
Thanks for the update! I just marked your reply as the solution :)
JohnCarloV
NETGEAR Community Team
